Yamaha Factory quickshifter
razz007
6 hours ago, drell8345 said:
I have a 2023 World Raid and have been looking at the QS I know it has the Standard rally version and acceptable to fit, but I can't seem to find if the World Raid is suitable.  can some let me know.
Hi
I eventually managed to install QS to my World Raid BUT to do that you need ECU tune (flash) with QC enable map. Any tuner has it.
I bought cheap OEM Honda QS sensor here
https://www.aliexpress.com/item/1005006175109337.html  70usd
You need to wire one wire to ground, other one to PIN no 22 in ECU.
Here is pin you need to buy
You need to modify some threads (check the photos)
Results:
QS is working perfectly, in ride you can upshift any rpm without clutch while holding throttle.
