Since @Aleksandar13 is no longer selling modified ABS rings for speedo correction,  I just noticed this source over on another forum. If you're not familiar with the reason for purchasing a modified ring, check out this thread.
I have no dog in this hunt, just passing along a link if someone is interested.  Note the post is their first and has no established reputation there so "Caveat emptor".
https://www.advrider.com/f/threads/t7-abs-rings.1680765/
  • Members
Good hint!
Off-the-road.de sell them, too - might be interesting for our EU members.
Modifizierter ABS Impulsgeberring für Tachoangleichung Yamaha Tenere 700   Der Tacho der Tenere 700 eilt leider stark...
I'll send the cut file to anyone who dm's me.
10 hours ago, Tenerider said:
Good hint!
43 euro for 2; 50 euro to post to Australia.
Not bloody likely
  • Members
Not bloody likely
That's ridiculous. I bet they'd fit into a small envelope.
Take my cut file to your local laser/waterjet cutter and ask for two (measure the thickness of your original ones, as I don't remember how thick the material is), made out of magnetic stainless, or carbon steel if you plan to powder coat/paint them. Unfortunately, most of these shops have a minimum charge. The shop I used was $75. I got 6 rings for $75. Gave away one set. Likewise, powder coaters will charge a minimum unless you want to wait until your color is being applied, then you probably could get it for free.
Not bloody likely
A package that fits through the mailbox, up to 1 kg, costs about €20 to australia. I can help sending it if needed.
www.bikebrothers.nl
Thanks for the offer.
I generally ride with a GPS which gives a good indication of speed.
The correction rings would be a bit of luxury and not vital.
If anyone is replacing with corrected rings or has a spare set; I'm interested in a pair of the stock rings. North America preferred.
DM me. Thanks!
I don’t suppose you have the cut file for the 17/17 Supermoto conversion abs rings do you? 🙏🏻
I’ve messaged Aleksander but it’s along time since he’s been on this forum ☹️.
  • Community Expert
Which wheels are you using? Mt-07 conversion or aftermarket plug and play wheels? What tyre sizes?
  • Community Expert
For the community: I’ve uploaded drawings for abs rings from 36 through 44 holes here
https://drive.google.com/drive/folders/1cnbfSHJsD2LKWwHAppZc-cJp3Xyh752h
Only personal (non-commercial) use please.
Material must be magnetic. Thickness 1.5mm.
Here’s some reference combinations:
Speed corrected stock wheels: 42 front/rear
Speed corrected 17”/17” wheels: 36 front 40 rear
Feel free to use the other sizes to get a combination that suits your specific wheel/tyre combo. I take no liability for providing these drawings free.
You’re welcome
Edited by rfdg
