Adventure Specs side plates compatability
Brodixv8
Does anyone know if these are compatible with the Yamaha OEM rear rack ?
AS apparently never tried them.
I’ve an oem rack ( not fitted ) I can’t see how any side plates fit with it
I’ve R&G ones
from the look of it - it fits exactly not sure how you’d fit the side racks in
Edited by Lewie
I’ve R&G ones
The AS side plates utilise the OEM mounts plus add 1 other each side. I had them on a '21 Tenere but had an Outback Motortek rear rack. Just had to use longer bolts. I can't see why they would'nt work with the OEM rack, but i have to get the plates from the UK ( i'm in NZ ) = big cost and just want to be sure they'll work.  Hopefully someone else has them. Thanks for responding regardless. Kind regards. Geoff.
They will fit but you need 20mm longer bolts, I have a cut down OEM rack the lower arms that attach at the footrest mounts are removed and the Adventure spec lower attachments fitted, there is a post on here about the rack.
Do the side plates then go on after the rack?
my rack is cut down but I need to try to find 2 spacer as it didn’t come with them
think the bolts are m8 x 70
Thanks. Thats helpful. G.
