Posted March 18, 20241 yr First, credit to this gentleman....I got motivated after seeing the below vid on YouTube: So, went out and picked up the following: Carpuride W502 Motorcycle GPS Wireless Portable Apple Carplay/Android Auto Waterproof Car Stereo, 5" IPS Touch Screen with Dual Bluetooth, Navigation/Siri/Google Assistant for Motorbike https://a.co/d/dnvZu0x BRCOVAN Aluminum Alloy Mini Mount Base with 1'' TPU Ball for Rails Diameter 0.39'' 0.47'' 0.55'' 0.63'', Compatible with RAM Mounts B Size 1 Inch Ball Socket Arm https://a.co/d/0BqCOkB RAM Mounts RAP-B-201U-A Composite Double Socket Arm - Short Arm Compatible with B Size 1" Ball Components 503 - Service Unavailable Error Installed the set up today. Pics below: Works for the most part and it's nice to have your GPS front and center. I'm having issues getting my helmet BT communicator to play nice with the Carpuride unit but I'll figure it out. Edited June 24, 20241 yr by SXXP Corrections
March 18, 20241 yr Author Yes, phone, Carpuride, headset. Phone to Carpuride - Works Phone to headset (with Carpuride offline) - works! Phone to Carpuride to headset - No joy (sound)!
March 18, 20241 yr It's generally better to use your phone as the hub and connect all devices to it rather than to daisy chain devices. I know with Android under the Bluetooth settings, you can control which device receives audio, and imagine iPhones have something similar. It's best to disable audio to your carpuride and enable it to the headset. This way your phone will have a connection to your headset for audio and a connection to the carpuride for control, so you can skip songs, etc. advgoats.com
March 18, 20241 yr I must be a bit of a Luddite but I would rather stick pins in my eyes than be constantly connected to my phone. When I am out riding I don't want phone calls, messages, music, emails etc. Same in the car. I have a charging cable in the car but as soon as I use it Ford's android auto kicks in with all sorts of Shet on the touch screen. I have to fiddle around just to get back to the radio screen. That's why I use a Garmin 700 with a 650 for back up. Just me and aren't we lucky we are all individuals. Alcohol! No good story starts with a salad.
March 19, 20241 yr Author On 3/17/2024 at 11:06 PM, random1781 said: It's generally better to use your phone as the hub and connect all devices to it rather than to daisy chain devices. I know with Android under the Bluetooth settings, you can control which device receives audio, and imagine iPhones have something similar. It's best to disable audio to your carpuride and enable it to the headset. This way your phone will have a connection to your headset for audio and a connection to the carpuride for control, so you can skip songs, etc. No joy on the sound after messing with all the BT settings on my phone for both the Carpuride and helmet communicator. Sound/music plays just fine , but as soon as Android Auto establishes a connection and the default GPS screen pops up, the sound gets cut off. The track being played continues to display and count down on the Carpuride screen, just no sound in the helmet. I've reached out to Carpuride, but crickets so far!
March 19, 20241 yr 8 minutes ago, SXXP said: No joy on the sound after messing with all the BT settings on my phone for both the Carpuride and helmet communicator. Sound/music plays just fine , but as soon as Android Auto establishes a connection and the default GPS screen pops up, the sound gets cut off. The track being played continues to display and count down on the Carpuride screen, just no sound in the helmet. I've reached out to Carpuride, but crickets so far! I wonder if Android Auto is doing something funky with audio routing. What headset are you using? advgoats.com
March 19, 20241 yr Author 1 hour ago, random1781 said: I wonder if Android Auto is doing something funky with audio routing. What headset are you using? Amazon.com
March 20, 20241 yr You double downed on the Chinese products! Let us know if you get it figured out. advgoats.com
March 20, 20241 yr Author 2 hours ago, random1781 said: You double downed on the Chinese products! Let us know if you get it figured out. Figured it out...I'm an idiot! Works well and for a low budget system the sound quality is surprisingly good. Now to take down my negative review on Amazon!
March 20, 20241 yr Author 9 hours ago, Lewie said: And the problem? Can't read directions....😕 The default "Sound Output" was set to the Carpuride itself. I probably stared at that screen multiple time and never caught it😬. Changed it to the the helmet headset and all was good. Fiddling with the equalizer feature on the Carpuride really ups the quality of the sound (music) going to the helmet - way better than direct phone to helmet. I was very pleasantly surprised at the quality/difference in sound once I got it to work. So, first impressions for my very first helmet communication system is very positive (user error aside)! For a budget system ($239 Carpuride head unit + $80 Martian helmet communication system) giving you all the Android Auto/Apple Carplay functionality I'm quite happy. Of course, how it holds up long term, only time will tell....fingers crossed! Regrets? Maybe not going with the 7" version for not a whole lot more money. Bigger is better, right 🥴? Edited March 20, 20241 yr by SXXP
March 20, 20241 yr When I had my cardo- Zumo and iPhone I couldn’t get the intercom to work reliably so I stopped the cardo taling to the Zumo
March 30, 20241 yr Author Decided the 5" screen was too small, and returned/exchanged it for the 7" version : Amazon.com: Carpuride W702 for Motorcycle, 7 inch Waterproof Touchscreen, Portable Apple Carplay/Android Auto GPS Navigation for Motorbike, Support Dual Bluetooth, Car GPS, Siri, Google Assistant, TF-64G : Electronics Buy Carpuride W702 for Motorcycle, 7 inch Waterproof Touchscreen, Portable Apple Carplay/Android Auto GPS Navigation for Motorbike, Support Dual Bluetooth, Car GPS, Siri, Google Assistant, TF-64G: Car Stereo... About 20 bucks more. Much better! Edited June 24, 20241 yr by SXXP
March 30, 20241 yr 11 hours ago, SXXP said: Decided the 5" screen was too small, and returned/exchanged it for the 7" version : Amazon.com: Carpuride W702 for Motorcycle, 7 inch Waterproof Touchscreen, Portable Apple Carplay/Android Auto GPS Navigation for Motorbike, Support Dual Bluetooth, Car GPS, Siri, Google Assistant, TF-64G : Electronics Buy Carpuride W702 for Motorcycle, 7 inch Waterproof Touchscreen, Portable Apple Carplay/Android Auto GPS Navigation for Motorbike, Support Dual Bluetooth, Car GPS, Siri, Google Assistant, TF-64G: Car Stereo... About 20 bucks more. Much better! Every inch matters! advgoats.com
March 31, 20241 yr When you're running Android Auto/Apple Play, how bad does it deplete your phone battery? My understanding is your phone is kinda the master/controller and the display is relatively dumb
March 31, 20241 yr Author In the short duration rides that I have done so far, I haven't really had cause for concern.. But then again, I now have all kinds of power sources added to the bike so I can keep the phone charging while riding. I'll test out your concern on a day ride soon and report back.
