High Exhaust w/ Gen 1 OM Pannier + OEM Tail
Invicta084
Hey all,
I have been looking to add a high exhaust to my bike, I have looked at the Camel, MIVV, HPCore, and Huzar, all seem to be incompatible with panniers and the OEM tail.  Does anyone know of  a high exhaust that  will work with the gen 1 outback motortek pannier rack and the OEM tail. Not opposed to replacing the tail if that is the issue.
Thanks!
The standard tail has two qualities that matter to me: it keeps the mud off my back, and it protects all the wiring. I will mount the HP Corse (if it ever gets here) and I plan to move my turn signals up to the tail light. That was demonstrated on this forum, but I can't find the post now. You can see how it would work:
image.png.d7fca6a557180f7932aa50f15efdda0d.pngimage.png.2a48790aae9cd3d551f06b21c3faace6.png
That is a good idea, do you happen to have a pannier rack as well? Would love to know of a high exhaust that works with the panniers.
The Mivv, the Huzar, and the HP Corse all tuck inside the bracket that holds the stock exhaust. The biggest issue I’m aware of with fitting pannier racks is all the wasted space of racks sticking out far enough to clear the standard pipe.
I'm just fitting the high HP Corse SP1 exhaust and was looking at the Kriega OS36 set up for soft panniers.  Has anyone tried that and how does it work with the high exhaust, any heat issues with the harness or panniers?
I will be fitting a tusk soft rackless system around my hpcorse enduro bend exhaust or at least attmpting to in the next couple weeks. Bought it used off marketplace and just need to meet up to get it.
I ended up getting a Huzar high exhaust, from the trial fitting, it seems like it will work without issues with my Outback Motortek Panniers. The can is close to the stock tail lights, but the outlet on the 50cm exhaust seems to clear just fine. Just need to cut the piece to fit it to the inner frame, which kills me, but it is what it is.
Just learned that Outback Motortek has a pannier rack for the tucked in high exhausts, and it's available in the U.S.
Yamaha Tenere 700 Pannier Racks Compatible with our Rear Rack Combo. We offer both Standard and X-Frame pannier racks. The X-Frame for the Yamaha Tenere 700 are the most universal and functional side pannier frames...
When I mounted my HP Corse high pipe I realized the above solution won't work for me. I have a 2024 Tenere and I want to keep the standard LED taillights, and they mount in those funny oval openings. My current and temporary redneck solution is a some plastic cut from an old mailbox newspaper tube.  I'm trying to describe it and I can't, so I'll  have to take a picture and show it, even though it's embarrassing. Maybe it will inspire someone with more skills to develop and elegant bracket. I'll bet you could achieve something phenomenal with a 3D printer.
