Oem wheel Valve Stem
Bobby
Go to solution Solved by toddiscdn,
2023 600 miles - front tire is flat - I found the leak at the tire valve stem near where the bolt screws down. Can’t find that part - any idea what valve stem I am looking for to replace it ? The bike came with tubeless Pirellis
thanks !
  • Solution
It may say tubeless, but theres a tube in there.
Whip that front tyre off and whack in a new tube. Simples!
It looks like the tire may have spun a bit on the rim and ripped the valve stem off the tube. What pressure were you running?
