Posted March 30, 20241 yr Does anyone know if the rear wheel sprocket carrier from an MT07 is a match for the T7?
March 30, 20241 yr Moderators 1 hour ago, Alan M said: Does anyone know if the rear wheel sprocket carrier from an MT07 is a match for the T7? If you're referring to what is listed as the OEM, "Clutch, Hub",(#6) then probably yes. At least the part numbers are the same as listed here. Part #10 on the Mt-07. Shop 2019 Yamaha MT-07 REAR WHEEL OEM Parts Diagram - RevZilla 2019 Yamaha MT-07 REAR WHEEL assembly detail & product fiche. Shop original factory replacement parts at RevZilla today! https://www.revzilla.com/oem/yamaha/2021-yamaha-tenere-700/rear-wheel?submodel=tenere-700-xtz7mb "Men do not quit playing because they grow old, they grow old because they quit playing" Oliver Wendell Holmes - Mods - HDB handguards, Camel-ADV Gut guard, 1 finger clutch, The Fix pedal & Rally pipe, RR side/tail rack, RR 90nm spring & Headlight guard, Rally seat, OEM heated grips- stablemate Beta 520RS
March 30, 20241 yr Author Thanks, yes, I just checked on Fowlers parts list and looks like they’re the same. Had brain fade earlier, should have checked there first. Cheers 👍
