Posted April 5, 20241 yr Weather is terrible in Scotland at the moment, not much fun riding the T7. Off work and bored so made this wee alignment tool today. Basically a turned down alloy bar with a removable 20mm tapered bullet. It works like a charm and makes axle fitting easier. I change wheels out quite regular, road/off road, probably not really an issue for most.
April 6, 20241 yr Author 6 hours ago, mcbrien said: It centers the wheel so the axle slides in easier? Yeah, the thin rod end slides through keeping everything together, then you just tap the axle through and the bullet section centres for the axle to pass through easily. As I said, probably not a biggie for most but handy if you’re regularly swapping wheels.
April 6, 20241 yr I’ve been using an air wedge to raise the rear wheel into the correct position for the axle install…..easy! I also zip tied the caliper to the swing arm when I owned my Tenere 700….another problem solved. https://www.amazon.com/IMPROVED-Commercial-Professional-Alignment-Inflatable/dp/B07XB4BFPP/ref=asc_df_B07XB4BFPP/?tag=hyprod-20&linkCode=df0&hvadid=385272107002&hvpos=&hvnetw=g&hvrand=2334115563075853467&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9022415&hvtargid=pla-828600367169&psc=1&mcid=713a8430f5b9311aaa670d0dd83f9dbc&tag=&ref=&adgrpid=78829231656&hvpone=&hvptwo=&hvadid=385272107002&hvpos=&hvnetw=g&hvrand=2334115563075853467&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9022415&hvtargid=pla-828600367169&gclid=Cj0KCQjw5cOwBhCiARIsAJ5njuYNED2ysdV7iby_mWtq5xU7_CAOuB5mJ-U8ruPzxDnj5eUWFnkG0LoaAukVEALw_wcB
April 6, 20241 yr I roll the wheel up the toe of my boot to get it to the right height then curse myself because the axle is sitting on the garage floor just out of reach. I’m digging these good ideas!
April 6, 20241 yr I saw these air bag setups at Home Depot and couldn't think of anything I could use them for. Have to go back and check them out.
April 6, 20241 yr Author Axles always seem to be just out of reach 😁. Good tip with the axle, especially out in the dirt is to stick it in the exhaust instead of on the ground. Keeps the crap off it and easy to hand. Edited April 7, 20241 yr by Alan M .
April 23, 20241 yr Reverse the direction of the axle ( i.e. the nut is on the brake disc side) to make it easier to undo out on the trail.
