Hi folks!  I’m just wondering if anyone out there in Tenere land knows which hand guard sets sit closest to the bar.  The reason I ask is that I recently installed the Twalcom dash mod (mounts the instrument cluster and GPS/phone side-by-side), and I’m looking for the lowest-profile quality hand guards that give the most clearance between the hand guards and the dash when the bar is swung full lock.  Any ideas?
Unfortunately I don’t have any pictures with swung full lock available but maybe it will give you an idea about the bracket position and approximate dimensions with just these pictures:
Acerbis Endurance X:
If you look closely at the 2nd picture, you’ll see a small round spacer in between the bracket and the guard-rail. You could potentially leave this spacer out and save one more centimeter I guess. Fitment will get slightly worse without the spacer possibly.
I’ve got the Motology setup which is slightly different to yours but I found my barkbusters were too close for comfort to my dash. I installed some 25mm bar riser spacers and now have plenty of clearance. Might help your situation 🤷🏻‍♂️
The HDB guards currently on my T7 are much further from the grips than the Barkbusters installed prior if that helps.
  • Members
Acerbis X-Factors (they come with the same black aluminium bars as most Acerbis guards) did hit my standard dash, since I've flipped my bar risers. I had to grind off the ends a bit.
