I'm looking for info on the heated grip plug that is on the Tenere 700, (the plug where the yamaha oem heated grips plug into the tenere 700 oem wiring harness)
What type of plug connector is it? (type, male, female)
Where is it?
And does anyone have any good clear photos of it?
As I understand, this is the heated grips adapter cable from Yamaha:
Which end plugs into the bike oem harness? and which end plugs into the yamaha heated grips cable?
And, what type of connectors are they? (model, and maybe where I could order one)
I'm looking to make an aftermarket set of heated grips, plug directly into the tenere 700 wiring harness (using the same plugs that the yamaha oem heated grips use, so its a plug-n-play install)
Tazmool
Greetings Everyone,
Where is it?
Thanks in Advance!
Tazmool
5 answers to this question
Register a new accountSign in
