Fitting SW-Motech Street Rack with Bumot Rear Rack
Peter_W
Hi there,
here is my idea of a slim luggage rack, consisting of the above components. On the Bumot Rear I removed the two outer handrails to create a tight-fitting carrier that also leaves space for removing the rally seat.
greeting
Peter
Edited by Peter_W
On 3/26/2020 at 5:47 AM, Peter_W said:
Hi there,
greeting
Peter
That looks the best setup I have seen so far. Everything you need nothing you dont.
  • 4 years later...
Hallo Peter,
Does the SW-Motech Street rack fit precisely on the Bumot rear rack or did you have to re drill the mounting points?
Look forward to hearing from you.
