Posted April 30, 20205 yr Popular Post I have just installed a tool tube on the Adventurespec side rack. It's the smaller 90mm diameter one, nice snug and inconspicuous fitting . I also have a 110mm diameter one but looked like it will interfere with the chain and or swingarm. Which is a shame as it holds so much more.
April 30, 20205 yr 3 hours ago, Louis said: I have just installed a tool tube on the Adventurespec side rack. It's the smaller 90mm diameter one, nice snug and inconspicuous fitting . I also have a 110mm diameter one but looked like it will interfere with the chain and or swingarm. Which is a shame as it holds so much more. Top job and nearly invisible! That looks so neat. Will tyre levers/irons fit it out of interest? Cheers
April 30, 20205 yr Author Yes, the tube is about 300mm long. I was going to use it for puncture repair setup myself. I will have a play around with it and will post my set up. Stay tuned for update.
April 30, 20205 yr 6 hours ago, Louis said: Yes, the tube is about 300mm long. I was going to use it for puncture repair setup myself. I will have a play around with it and will post my set up. Stay tuned for update. Brilliant and thanks. I'm sure many would be interested in your findings. I'll be getting exactly the same Adventure spec top rack and side racks.
April 30, 20205 yr Author Just finished packing up my puncture repair setup version 1.0 for the tube, ALL fits in. I already have a EBay sourced canvas tool roll. Good for keeping the rattle down and organised. Please note on the 19mm spanner is used for front axle removal, it has a piece of 19mm hex which I drilled out the centre for lightening, nice fit on the spanner. Motion Pro bead breaker tyre levers, 27mm tyre lever/ spoon for rear axle. 10/12mm spanner for front axle removal and chain adjuster. Also found a square plastic container which I use a piece of foam to hold it in the top of the screw on lid. Container has glue, patches, sandpaper and spare valves. The hand pump is outside of the toolroll. I do have an electric pump, it would have fit in the larger diameter tube which sadly wasn't a good fit. I also fit a zip lock bag of talc which I thought of after photo shoot. Version 1.2. Improvement comments please.... for version 1.3
May 1, 20205 yr Hi Leon, Firstly, thanks very much for your advice last week - much appreciated. Your kit looks great - the Motion Pro Beadpros are a great piece of kit (and they are nice and light) as well as the valve puller tool that can save a lot of skin off the knuckles! The only additions that I take are a couple of 25oz CO2's and adaptor, and some "windex" (some use dish washing detergent) in a hotel shampoo container to help with the tyre fitting. Paul
May 1, 20205 yr Author Hi Paul, who's Leon? Must be predictive text.🤣 The tube is packed tightly so no room for CO2 or I have to dump the hand pump. Great idea with the detergent! Any detergent will lube rubber. Will try to find room. Leon said many thanks. Louis
May 1, 20205 yr Author 2 hours ago, Mungo said: Hi Leon, Firstly, thanks very much for your advice last week - much appreciated. Your kit looks great - the Motion Pro Beadpros are a great piece of kit (and they are nice and light) as well as the valve puller tool that can save a lot of skin off the knuckles! The only additions that I take are a couple of 25oz CO2's and adaptor, and some "windex" (some use dish washing detergent) in a hotel shampoo container to help with the tyre fitting. Paul Update; small bottle of detergent crammed in, lube the lid thread to make it easy to install. Cheers Louis Edited May 1, 20205 yr by Louis
May 1, 20205 yr Sorry Louis, Unfortunately I can't use the excuse of predictive text - was plain old "dumb Paul" or I could use the Alzheimer's excuse. I tell my wife it's Adventure before Dementia, however she says for me it's Adventure with Dementia. Regards Paul (I think!)
May 1, 20205 yr On 4/30/2020 at 1:28 PM, Rich TT said: Brilliant and thanks. I'm sure many would be interested in your findings. I'll be getting exactly the same Adventure spec top rack and side racks. Would you mind sending a link to your actual tube where you bought it from? I've seen a few and they vary in price quite a bit. Thanks Rich
May 1, 20205 yr Author 4 hours ago, Rich TT said: Would you mind sending a link to your actual tube where you bought it from? I've seen a few and they vary in price quite a bit. Thanks Rich Universal Off-Road Motos Motorcycle Waterproof Tool Tube Gloves Rain(Size L) Type: L Tool Tube Box. Tool Tube is the ultimate, rugged and versatile solution for transporting and storing tools and much... I hope this link works.
May 2, 20205 yr 7 hours ago, Louis said: Universal Off-Road Motos Motorcycle Waterproof Tool Tube Gloves Rain(Size L) Type: L Tool Tube Box. Tool Tube is the ultimate, rugged and versatile solution for transporting and storing tools and much... I hope this link works. Perfect, thanks! Rich
June 7, 20205 yr Hi all just bought my Tenere 700 and really conscious of weight after coming from the too heavy Africa twin . my question is are the Adventure spec rack and side panels light weight? they look exactly what I’m looking for regards Dave
June 7, 20205 yr 1 hour ago, David Adams said: Hi all just bought my Tenere 700 and really conscious of weight after coming from the too heavy Africa twin . my question is are the Adventure spec rack and side panels light weight? they look exactly what I’m looking for regards Dave They are really light weight as they are made of aluminium. When I received them I was pleasantly surprised how super-light they are. Still, they are sturdy enough as my left side already took a big hit once. It bent a little and I bent it back at home with a BIG hammer 🙂
June 7, 20205 yr Author Yes! Lightweight, I am coming off an Africa Twin myself. The rear rack and crash bar protectors are also quite lightweight from Adventurespec. Highly recommended!
June 8, 20205 yr Hi David, I have the Adventure Spec rack (without the side panels) and it weighs 1.6kgs - and I love it - fits well, is extremely practical, and looks great.. I also have the Adventure Spec Crash Bars - another great product - it weighs 3.1kgs Paul
June 8, 20205 yr On 5/2/2020 at 8:37 AM, Louis said: Universal Off-Road Motos Motorcycle Waterproof Tool Tube Gloves Rain(Size L) Type: L Tool Tube Box. Tool Tube is the ultimate, rugged and versatile solution for transporting and storing tools and much... I hope this link works. If you can’t find one online, these tool tubes are actually tractor document holders - you can get one from an agriculture/tractor place for about $15 (Australian).
June 8, 20205 yr On 5/1/2020 at 1:29 AM, Louis said: Just finished packing up my puncture repair setup version 1.0 for the tube, ALL fits in. I already have a EBay sourced canvas tool roll. Good for keeping the rattle down and organised. Please note on the 19mm spanner is used for front axle removal, it has a piece of 19mm hex which I drilled out the centre for lightening, nice fit on the spanner. Motion Pro bead breaker tyre levers, 27mm tyre lever/ spoon for rear axle. 10/12mm spanner for front axle removal and chain adjuster. Also found a square plastic container which I use a piece of foam to hold it in the top of the screw on lid. Container has glue, patches, sandpaper and spare valves. The hand pump is outside of the toolroll. I do have an electric pump, it would have fit in the larger diameter tube which sadly wasn't a good fit. I also fit a zip lock bag of talc which I thought of after photo shoot. Version 1.2. Improvement comments please.... for version 1.3 Do you actually use glue and patches when you puncture a tyre? Not just put in a new innertube? I am used to drive bikes with tubeless tyres, so put in a plug and drive. This is my first bike which is not tubeless. So n00b on inner tubes 😉 On 5/1/2020 at 1:29 AM, Louis said:
June 8, 20205 yr Author Tube tyres are like a bicycle, patch and glue the hole in the inner tube. Refit the tube inside the tyre which happens to be a tubeless tyre but not tubeless rims. Add air.👍
June 12, 20205 yr On 6/8/2020 at 12:06 AM, Louis said: Yes! Lightweight, I am coming off an Africa Twin myself. The rear rack and crash bar protectors are also quite lightweight from Adventurespec. Highly recommended! I have been contemplating a lot what pannier setup to get. Decided I need some rack system to get the storage I need. Gone for outback motor tech. With X frame fuel storage. Aluminium panniers are a big no no for me there 6 kg each (I weighed my last lot. So soft panniers with steel rack. ( I like the AS side panels but don’t think they would support a decent size soft pannier.) ps how good is the Tenere compared with the AT ! Way too heavy
June 13, 20205 yr Author Once you add luggage to the AT it starts to become harder to handle in offroad conditions, it's fine on the highway. Tenere has plenty enough power for an adventure bike. Not sure what luggage you are trying to strap on, but the Adventurespec racks are extremely strong. Don't let the notion of aluminium construction sway you. Lightweight and strong! ONLY 2kg and rear rack is 1.6 kg. Edited June 13, 20205 yr by Louis Update information
