AZJW T700 Build & Mnt. Records
AZJW
15 hours ago, SXXP said:
The pre-filter in one of your earlier pics, do you use that only with foam/oil filters, or also with the stock paper filter?  How often do you clean the foam/oil filters?  I've found if I check my WR450's filter after letting it sit for a couple of months, the oil on the filter has lost it's tackiness and I end up cleaning a perfectly clean filter just for peace of mind.  I use Maxima filter oil.
Any particular reason for the longer shock bolt?
The foam Pre-filter is used in conjunction with a foam main filter. It's noted above, but it's a UNI of Australia filter set, not to be confused with UNI filters in North America.  Service intervals are done every 4,000 miles when I do my oil changes.
Link takes you to the discussion about the shock bolt. My post (7th from top) details a U.S. source.
https://www.tenere700.net/topic/7595-rear-shock-bolt-too-short/#comment-82481
On 3/22/2024 at 8:26 PM, AZJW said:
3/21/24 - 18, 547 miles
Changed out lower shock bolt for longer Racetorx replacement.
Quality fasteners are a thing of beauty.
advgoats.com
