Diagrams and technical specs
MGG
tracking2_thumb.ashx
How's it compare to other mid-sized adventure bikes?
tenere-frame.ashx?h=493&w=740&la=en&hash
270-degree_a.ashx?h=300&w=740&la=en&hash
2019 Yamaha Ténéré 700 Spec
Capacity
689cc
Bore x Stroke
80.0mm x 68.6mm
Engine layout
parallel twin
Engine details
8v dohc, l/c
Power
72.4bhp @ 9000rpm
Torque
50.2 lb.ft @ 6500rpm
Top speed
125mph (est)
Average fuel consumption
mid/high 40mpg (est)
Tank size
16 litres
Max range to empty
175-190 miles (est)
Rider aids
switchable ABS
Frame
steel tube
Front suspension
43mm KYB usd forks
Front suspension adjustment
fully adjustable
Rear suspension
KYB monoshock
Rear suspension adjustment
fully adjustable
Front brake
2 x 282mm discs, two-pot calipers, ABS
Rear brake
245mm disc, one-pot caliper, ABS
Front tyre
90/90-R21
Rear tyre
150/70-R18
Rake/Trail
27°/105mm
Wheelbase
Seat height
1595mm
Kerb weight (est)
875mm
Warranty
unlimited miles/2 years
Website
www.yamaha-motor.eu
EDIT: ... I decided to add all the measurements I can find to this thread, that way someone (including me) will find them useful when they run out of information.   🙂
Edited by MGG
added info at bottom of post
Nice charts and video link MGG, thanks for posting.
It does raise a few points for me. The first thing I noticed was no scavenging of the exhaust fumes in the dyno test room, not that this affects us, just the tester.
Looking at the charts the first thing people will notice is the drop off in power from around 6,200 rpm compared to the MT07. Probably not an issue to many riders but those doing higher motorway speeds, maybe with lots of luggage or a pillion this may be a slight disadvantage. This got me thinking about the tyres, mainly the rear one with those knobs and how this may effect the power/torque measured. They are not going to run as smooth over the rollers, or indeed the road, as pure road tyres will. It would interest me if a re-test was done with a rear road tyre to see if this indeed did effect the power measured at all. It may well just be the pipe/air box that differs from the MT07 causing this change in power, as there is also a small increase between 2.000 and 3,000 rpm as well on the Tenere. I wonder what people with good dyno knowledge think about this.
I am sure everyone has the xtz690 Manual by now ... but just in case ... https://mega.nz/#!XvAikIDL!uYy0MmpX32Yw1Y6rXmaUevV6UTGGdrDPmFsGJyNzI_Q
I can't attach it directly 10.3MB
Maybe a multifile ZIP ?
I do not think that the dyno run is good, too many small mistakes ... and the numbers are a bit lower than I expected especially since it has different gearing than MT07 so at least torque should be higher. On top of this, the torque and hp numbers are supposed to cross at 5252 by design, and this is not the case for T7 nor the MT07 so I think that the run might be flawed. We can still compare MT07 with T7 but not looking at proper resolution graphs is creating more questions in my mind. On the up side, I still have a bit to go before I can buy one in Canada 😉
ODB2 tips ... in French  ...
Un article expliquant comment faire le diagnostic des codes défauts sur la Yamaha ténéré 700. En utilisant un lecteur OBD2, c'est très simple!
ODB2 cable adapter for Yamaha
Yamaha ECU OBD2 Adaptor Cable Converter
Torque Settings anyone? ... it seem that if you ask your dealer, they will provide  them to you. In the meantime, here is a copy.
Tenere_700_Tightening_Torque_01_.thumb.jpg.4ebfe7d2ce8cf28750f95e297555832e.jpgTenere_700_Tightening_Torque_02_.jpg.b8129c7dc63af553e2e8c83aa3329b0b.jpg
  • Thanks 3
... I figured someone might need this at some point ... to build some nice mods...
https://hum3d.com/3d-models/yamaha-tenere-700-2021/
Yamaha Tenere 700 2021 3d model
They sell the 3D model with lot of options ...
and here is the model in 360deg ... https://hum3d.com/360-view/?id=211232
Edited by MGG
man, tempting to buy this model and make a 3D printed model w/ lights for my night stand 🤣
Thanks for this.
Original Footpegs Footrest dimensions measurements : width=~49mm    length=~86mm
The other footpegs above are from http://www.samracingparts.com/home/294-250-pedane-yamaha-tenere-t7-rally.html
See this thread: https://www.tenere700.net/topic/730-recommend-me-some-footpegs/
Edited by MGG
typo
Thanks for this.
If your interested, I don't mind splitting the cost of the model lol
the overlapped graph seems indeed correct to me (but not the rev scale in the graph with T7 alone) .
 5252 is the number for pound foot only !  Here they seem to plot wheel hp (left Y axis) and torque in Newton meters (right Y), therefore the magic number where both lines cross is different (should be about 7120 rpm)
@ScorpionT16 just saw this...right at this moment as currently in a financial bind 😛
but if you are interested toward end of the year, I am all for it.
