Inspect your wheel bearings...
ADVUSA
Your bearing will be fine, unless you;
A. Regularly jet wash your bike and hold the jet directly at bearings.
B. You ride through water upto the axles.
C. You’ve done huge mileage and they’re worn out.
Bearings are a wear N tear part, if you check your bike before each ride you should notice the play in a bearing before it fails like Roberts did. Bearings are also cheap and easy to replace.
