DonaNobisPacem's T7
DonaNobisPacem
Date of Purchase: November 24, 2021
Changes made (by the dealer):
  - T7 specific Zeta Adventure Armor Handguards (http://www.zeta-racing.com/handguard/ad_armor_tenere/index.html)
  - Zeta XC-Pro Protectors (http://www.zeta-racing.com/handguard/xcpro/index.html)
  - Zeta Adventure Armor Bumper Option (http://www.zeta-racing.com/handguard/adv_option/index.html)
  - Rally Raid 20mm Lowering Links (https://www.rally-raidproducts.co.uk/yamaha-t7-tenere/yamaha-t7-tenere-lowering-link-20mm)
  - Rally Raid Shortened Side Stand (https://www.rally-raidproducts.co.uk/yamaha-t7-tenere/yamaha-t7-tenere-short-shorter-side-stand-lowered)
  - Rally Raid Nylon Front Fender Screws (https://www.rally-raidproducts.co.uk/yamaha-t7-tenere/yamaha-t7-tenere-nylon-plastic-screws-fork-leg)
Edited by DonaNobisPacem
Entry Date:  November 27, 2021
Changes made:
  - Seat lowered by local upholstery shop
Entry Date: December 3, 2021
Changes Made:
   - Installed no-brand rear grab handles.
IMG_20211203_161516.thumb.jpg.9ea50534643a5f3ac74cf2de702cf09d.jpgIMG_20211203_162209.thumb.jpg.944dcae5a336d6d916e147ec238072f7.jpg
To be installed:
  - Rally Raid Uprated 80Nm Rear Spring (https://www.rally-raidproducts.co.uk/yamaha-t7-tenere/yamaha-t7-tenere-shock-spring-uprated-stiffer-heavier)
In transit:
  - Huzar High Mount Exhaust
  - CamelAdv 1-Finger Clutch Kit
  - Speedo Angels Dash Protector
  - Quadlock 12mm mounting kit
  - Seat Concepts 1-piece Low Comfort Seat
For consideration (in order of priority):
  - Leaky fuel cap fix
  - Dash/Headlight anti-vibration kit (CamelAdv or one of the 3D printed alternatives)
  - Auxiliary lights
  - Tail tidy
  - LED turn signals
  - Adjustable levers
  - Tank pads
  - Outex tubeless conversion
  - AXP Skid Plate
  - Crash bars
Entry Date: December 11, 2021
Changes Made:
   - Installed CamelAdv 1-Finger Clutch kit
To be installed:
In transit:
  - CamelAdv Anti-Bobblehead kit
  - TST Flush and BL6 LED turn signals
  - Tank pads
  - Tail tidy
  - Adjustable levers
  - Auxiliary lights
Entry Date: December 14, 2021
Changes Made:
   - Installed Quadlock mounting kit
To be installed:
In transit:
  - SW-Motech Skid Plate
  - Tank pads
  - Tail tidy
  - Adjustable levers
  - Auxiliary lights
Entry Date: December 15, 2021
Changes Made:
   - Installed SW-Motech bash plate
IMG_20211215_160907.thumb.jpg.d6aa4c33e2836729908e4addde25e8b1.jpgIMG_20211215_160915.thumb.jpg.531126162c3226de26da29ca0456d83f.jpg
IMG_20211215_161317.thumb.jpg.e74381780b692bae7b62ccb48d8b2943.jpgIMG_20211215_172725.thumb.jpg.5318c6e80e34bcd9643ca9edf1db19e7.jpg
IMG_20211215_172714.thumb.jpg.5f593bc02cec94d6f0f38182c6478554.jpgIMG_20211215_172743.thumb.jpg.7d9a1089f739f040ee82feda53b17c8f.jpg
To be installed:
In transit:
  - Camel Adv Anti-Bobblehead kit
  - Camel Adv Gas Cap Seal
  - Camel Adv Tail Tidy
  - Evotech Radiator Guard
  - World Walk G2 Tank pads
  - Adjustable levers
  - Auxiliary lights
Entry Date: December 17, 2021
Changes Made:
   - Installed Rally Raid Uprated 80Nm Rear Spring
   - Installed World Walk G2 Tank pads
To be installed:
  - Dual USB Socket with Voltmeter
In transit:
Backordered:
  - Adjustable levers
  - Auxiliary lights
Entry Date: December 18, 2021
Changes Made:
To be installed:
In transit:
Backordered:
  - Adjustable levers
  - Auxiliary lights
Entry Date: December 24, 2021
Changes Made:
   - Installed Huzar High Mount Exhaust
   - Removed passenger pegs
To be installed:
In transit:
Backordered:
  - Adjustable levers
  - Auxiliary lights
Entry Date: December 28, 2021
Changes Made:
   - Installed custom exhaust bracket Huzar High Mount Exhaust
   - Reinstalled passenger pegs
To be installed:
In transit:
Backordered:
  - Adjustable levers
  - Auxiliary lights
Entry Date: December 30, 2021
Changes Made:
   - Installed Careud TPMS system
IMG_20211230_155412.thumb.jpg.b2d020ac2474766b843f83de7f37d013.jpgIMG_20211230_155428.thumb.jpg.d66a922b77c0fe35596e2cb8f6b9f94c.jpg
To be installed:
In transit:
  - Zeta XC Flasher
Backordered:
  - Adjustable levers
  - Auxiliary lights
Entry Date: January 9, 2022
Changes Made:
  - Installed Camel Adv Tail Tidy
  - Installed Camel Adv Fork Guard Protector
  - Installed Camel Adv Gas Cap Seal
  - Installed TST LED Flasher Relay
  - Installed TST Flush front turn signals (temporary)
IMG_20220109_173316.thumb.jpg.7d74f72a933a355260da412b5607fb29.jpgIMG_20220109_173407.thumb.jpg.2acccf27f1d8007b0f6b1dc57e99068f.jpg
IMG_20220109_173338.thumb.jpg.a99cdb82ef253a426c5a88d8bd9cec4d.jpgIMG_20220109_173332.thumb.jpg.c2deaf5ec8c7c62b26a4d5a1c6f6e1d0.jpg
To be installed:
  - TST BL6 LED turn signals
In transit:
  - Zeta XC Flasher
Backordered:
  - Adjustable levers
  - Auxiliary lights
Entry Date: January 14, 2022
Changes Made:
  - Installed Seat Concepts 1-piece Low Comfort Seat
IMG_20220114_113803.thumb.jpg.d9c8450cd66fd490bef4591b50988a74.jpgIMG_20220114_120515.thumb.jpg.cbfaa7ca17256671d145ac26f5435e9d.jpg
To be installed:
  - Zeta XC Flasher
Backordered:
  - Adjustable levers
  - Auxiliary lights
Does your tail tidy have the tear drop shape holes that would accept OEM indicators that you know of?  Many of the aftermarket ones have a round 10mm hole for aftermarket indicators only.
Yes, the latest version of  Camel Adv's tail tidy has the OEM teardrop holes. They also provide the 10mm adapters needed for the usual aftermarket signals.
Entry Date: January 15, 2022
Changes Made:
  - Installed custom made plate bracket with turn signal mounts
  - Installed TST Flush mount turn signals as front signals
  - Installed TST BL6 LED turn signals as rear signals
  - Installed Zeta XC Flasher
  - Installed Dual USB Socket with Voltmeter
Backordered:
  - Adjustable levers
  - Auxiliary lights
Entry Date: January 16, 2022
Changes Made:
  - Installed 1w 220Ω resistors on front turn indicator wiring to fix dash indicator not flashing
Backordered:
  - Adjustable levers
  - Auxiliary lights
Entry Date: January 25, 2022
Changes Made:
  - First scheduled maintenance (oil and oil filter change) performed by the dealership (Odo at ~720km)
Entry Date: February 23, 2022
Changes Made:
  - Installed Evotech Radiator Guard
  - Installed Grip Puppies
Changes Made:
Backordered:
  - Adjustable levers
  - Auxiliary lights
Those USB sockets with voltmeters are super handy. Very cheap too. Have you experienced any issues with your rear right turn signal melting as a result of its proximity to your exhaust?
Not at all. Although they're right below the exit, they don't actually make any contact with the exhaust itself so I'm pretty confident there won't be any melting issues.
  • 5 months later...
Entry Date: July 29, 2022
Changes Made:
  - Installed Cyclops Adventure Aurora LED kit
Box contents.
Installing the mounting bracket + lights. There's a couple of bolts and a rubber cover that you have to remove and replace with the mounting kit.
Tucking in the controller. The manual recommends that you tuck the controller in and have all the cables come out from the left/clutch side of the bike, but I changed it up such that only the cables connecting to the LEDs themselves exit from the left while having the power and high beam cables exit directly from the right.
Plugging into the accessory power and tapping the high beam wire. Since I had these cables coming out from the right side, I didn't have to loop them behind the forks as recommended by the manual.
Connect, zip tie and tuck away the extra long cables coming from the LED lights.
Putting it all back together.
Entry Date: August 10, 2022
Changes Made:
  - Removed World Walk G2 Tank pads
  - Installed TechSpec 7-piece tank pads
Entry Date: October 17, 2022
Changes Made:
  - Installed SRC Upper and Lower Crash Bars
Note: Upper crash bars are incompatible with the Cyclops mounting beneath the steering head. I have temporarily removed mine until I acquire new mounting brackets to mount them on the crash bars instead.
IMG_20221017_202105.jpg.e780a5f6715acb15c40073b954ee8c12.jpgIMG_20221017_202119.jpg.4e77f747e4e655edfcab5fb476333333.jpg
Note: Lower crash bars are incompatible with the SW-Motech skid plate. I had to cut off a bit on the sides to make some space.
Even after trimming the skid plate, clearance is still tight. Especially on the right side of the bike, where there's barely a millimeter of space between the skid plate and the lower crash bars.
IMG_20221017_202301.jpg.ac0b571f8a55166aecde44336355191f.jpgIMG_20221017_202355.jpg.5d16b1351d91c2de46d205a6325fceaf.jpg
