T7 Suspension
prwatts
41 minutes ago, Aleksandar13 said:
Yes that's correct ,I've fitted 6.4nm springs .
Great, thanks Aleks, I’ll contact the supplier to find out the correct nm for my weight 😎👍
On 8/5/2019 at 7:44 AM, prwatts said:
Hallo Nick
Try this and see what you think:, turn the compression adjuster 6 clicks anticlockwise (softer)
Rear Shock Rebound (Base of the shock)  Turn anticlockwise 4 clicks
Rear Shock Compression (Top of the shock) Turn anticlockwise 5 clicks.
Front Rebound (top of forks):
Standard 17 clicks out
Delivered 15 clicks out (harder)
I set it to 20 clicks out
Front Compression (Base of forks, under a rubber plug you just dig out)
Standard 11 clicks out
Delivered 9 clicks out (harder)
I set it to 15 clicks out
To do this, you lie on the lounge floor carpet under the forks (I assume you are keeping the bike in the lounge for now 🙂 )
Seriously - lie down on the floor, look under the bottom of the shock. dig out the rubber stopper that keeps the dirt off the adjuster
Rear Shock Rebound (Base of Mono-Shock)
Standard 13 clicks out
Delivered 12 clicks out (Harder)
I set it to 16 clicks out
Rear Shock Compression Mono-Shock
Standard 15 clicks out
Delivered 11 clicks out (much harder)
Peter
Hi Peter, what do you weigh mate?  Just looking at some finer adjustments on mine ...
