What brand turn signals aftermarket are you using?
DanT700
Anyone use 2021+ MT09 LED turn signals (OEM Yamaha)? I really like that look, they are relatively inexpensive online and do not need any wire stripping or soldering.
One might need a new relay or maybe just use toe MT09 relay, I don't know.
On 3/29/2021 at 9:14 AM, JohnnieBoy said:
I went with the Yoshimura Tail Tidy kit and TST Industries leds. TST has everything needed to upgrade, including a  plug n play (adjustable) flasher relay. You have to use MT/FZ-07 for parts search but then everything you need comes up... including Yamaha end plug n play pigtails and plastic oval adapter block off plates. I went with the smoke flush mounts up front and the BL6 smoke pods in the back and am very happy. At $16 a pair up front and $30 in the rear - not breaking the bank, either. Right around $100 for everything to get the job done. Looks great and works well.
TST Ind link...
Want to upgrade your 2018 MT-07 with LED lighting, crash protection, fender eliminator, integrated tail light, and more? TST has you covered. Shop now!
I like your set up!
Couple questions on what exactly you bought from the TST website. For your front flush mounts.
You got the flush mounts, 3-3 harness adaptor, running mate and relay? Non of them came from the T7 selection? It all came from the MT07 selection?
Did the adaptor plates that came with the flush mounts work for the T7?
Id like to purchase the same thing  including the running mate and relay. Any help with that would be great. I guess I am a little confused as to why the flush mounts are not in the T7 section as well.
Joe
Edited by cannedSardina
Just been out and I’m now in market myself for new set flexi indicators
my ones were great but lately brightness has dropped where riders behind can’t see them easily
Edited by john_aero
TST Ind link...
I have the same TST setup, but using the Camel Tidy Tail.  Not sure how visible the fronts are during bright daylight...
Edited by roygilbo
fix
Looks like the Cyclops turn signals are not available any more (link)
And the 12oClockLabs TS700-RLA LED Turn Signals possibly have issues flashing (link)
What other options are there?
I need bright LEDs, strong and durable, front 3-wire running lights, no cutting, splicing or soldering.
Edited by discoganya
they look suspiciously like the ones used on the Tenere Rally.
Cyclops have discontinued the MF 3.0 lights because of some issues, but have recently purchased EDS Tuff Lites with a spring loaded stalk that can bend every direction & should have them upgraded with the same functionality as the MF 3.0 by end of year.  I tried the 12oClockLabs lights & returned them.
I saw that - but it's going to be a while before it becomes available to consumers I think.
Why did you return the 12oClockLabs signals?
If wanting extremely bright LED signals/running lights Skene (owned by Cyclops) has their High Visibility LED Light Systems for front & rear that when used with one of their controllers function as turn signals.  I've got them on the front as DRL & additional turn signals
Scroll about half-way down my blog review for full explanation
Thanks, I have read your blog in the past, very useful information.
Looks like T7 owners don't have many viable choices for plug-n-play turn signals right now.
I installed what CamelADV sells:
We tried dozens of different LED signal lights before deciding on these units. We've tested them on several bikes for over a year and haven't had any failures yet!These units are bright enough to easily be seen during the...
they are bright, durable and priced right. The only limitation is it’s a 2 wire setup, no forward running lights. I purchased along with the CamelADV tail tidy, highly recommended.
I have the TST flush mounted turn signals on my bike now, but I just melted one and they are disappointingly dim.
I used these on an older bike and I'm about to switch out with them:
Replace existing bolts with the MAL series Miniature LED License Plate Bolt to add additional light to license plates. Produces a wide 120° beam in one of 7 available colors to provide maximum visibility to make numbers...
They are indeed super bright, and they're $3 ea. Not sure why so many other turn signals are so expensive, fragile, and/or dim.
The same site also has these small/cheap terminal blocks that work great if you don't want to solder anything, and they're $0..29 ea:
LQC-x-Lever-Lock-Quick-Connect-Store_1.j
Lever-Lock Quick Connect Terminal Block for 28 to 12 Gauge wire. Alternative solution for traditional wire nuts to create quicker and more secure wire connections. Insert stripped wires and close the lever to secure wire and...
These are definitely minimalist: no running lights, fast blink (unless you swap relays/add a load resistor), and don't include harness/tear drop adapters. But if you find yourself in the group of people who don't care about turn signals as long as they work and you don't want to unnecessarily take money out of your beer fund, I'd recommend these.
advgoats.com
On 3/25/2021 at 4:17 PM, Firebolter said:
I used the Yamaha LED arrows with a R&G tail tidy and CAMEL High exhaust-no heating issues at all with the blinkers. Exhaust goes below the blinker.
https://live.staticflickr.com/65535/50956855426_f03be2a105_b.jpg
Any idea where to get these in
North America? My googling is failing!
@Ashmaxwell They look like what Camel ADV sells...
I use Kellermann micro. Newer black ones in the front, older (stowed away from another bike) silver ones in the back.
By mounting the MIVV Dakar exhaust I had to make certain changes to the back. I made the tail myself from stainless steel, welded on a tube with threads on both ends to meet the needs of the signal lights. The wiring goes through a hole in the middle of the tube into a rubber tube up to the tail light and so it's kept away from dirt and damage. The front ones are mounted via adapter plates from KEDO. The blinker relais is also from KEDO.
I've been super happy with these aluminum, waterproof, super-bright, E13 certified, and small LEDs that I got from Amazon. I've been running them for the last few months. They are excellent quality for the USD 43 price for a set of 4.
https://a.co/d/dAS04GB
I just installed the TST micro-LED turn signals. I used the Camel change plates, wire kit and flasher.
Easy peasy installation!
Are these brighter than the stock turn signals?
I’ve some rally ones to fit on the rear but I forgot what a faff it is to get to them
I can't say either way though I will say they vary bright looking straight at them. Not sure when the viewing angle changes from straight.,,,
