Lowering Link Added (Need HELP)
Rickywt
Hey guys so I added Yamaha Oem Lowering link to my T7, but I am confused to how I should adjust my Fork Tubes or how much MM should I bring it up?
Please help any answer would be much helpful
Edited by Rickywt
I also have the original lowering rods (18mm lower) and in addition the fork - which in the original is already a few mm through - to a total of 15mm through. I am very satisfied with this.
Following this post as I just took delivery of my T7 and although I’m 6’ tall I find it a bit tall in the saddle for me.
One rule of thumb is to drop the front 1/2 - 3/4 of the rear.  That said, I encourage you to experiment.  I find that I can tell a difference in as little as 2mm of adjustment, especially in the low speed handling.
Installed the Yamaha links about 3 weeks ago, found the left front fork 3mm higher than the right. I was using 7mm for stock fork height and figured +10mm would get me 17mm. I settled on 20mm for the forks and still have 3mm’s left to go up on the fork  grooves for the clamps.
The turn in and handling are great and I’ve run 100+mph with no wobbles or high speed headshakes.
On 10/18/2022 at 11:59 PM, smd3 said:
Rally Raid recommends 10mm on their site for their 20mm lowering link. I went with 8mm and haven't had any issues.
I'm sure 8mm with the Yamaha 18mm drop would be sufficient, too.
Same for me...if you look at the forks where they sit in the triple clamp, there is a smoothed section on the fork leg - with only limited scope to drop them. An 8mm fork drop worked fine with the RR 20mm lowering links. I'm 5' 10" and have never felt the need to lower a bike before, but the Tenere is a tall beast and carries its weight high up. Certainly best to fit the links before you drop the bike - unlike me!
The steep head angle of the bike keeps it super stable. I only raised my forks +8mm from stock and it’s fine at 100, too.
Moved from General Discussion.
Got 20mm lower links left the forks at the standard settings no effect on handling.
The best setting depends on you and how you ride. I would start by leaving the forks fully extended then go for a ride. Then raise them the same as the amount you lowered the bike. You should be able to feel a difference. That will give you a feel for how raising the forks changes handling. Then go to the setting that felt the best and start changing it in increments from there until you get to where it feels the best for you. The other choice is listening to the guys who only ride the freeway or like to do jumps and wheelies and do what they tell you.
  • 8 months later...
I'm thinking about installing the hyperpro 35mm lowering links. How much should I drop the front? They sell the kit for lowering the front and rear springs, but i think i will try to instal just the links adjust the fork and see how it feels, without changing the springs
