T7 charcoal canister removal
LateApex
When I pull the tank off that’ll get done.
Perfect spot for a little tool tube type deal.
I was thinking the same thing.  The unused motor mount in there would be a good place to build from.  It does get warm in there, wrenches might have to cool a little before they could be used.  Or I might try & fab up a piece of stainless tube that I can cook hot dogs in while I'm headed down the trail😆
  • Haha 3
That hot dog cooker idea is probably the single best thing I’ve gotten from this group.
I removed my canister earlier today, 15 minute job. For those considering this, it can easily be done without removing the tank. Just plug the line coming off the throttle bodies.
Can you just run a piece of fuel line from the right throttle body vacuum nipple to the left throttle body vacuum nipple - removing the need for the silicone blanking caps ?
This is what I did. In addition to plugging the line from the throttle bodies the vent hose should be extended through it's original mounts cast into the front sprocket cover. Besides not having to remove the gas tank or fairings this also leaves the tip over valve intact. I was able to remove the canister without cutting the rubber so after removal I reached in there and cut the top and right side off leaving the part around the starter intact. This will act as a bottom pad for a future tool tube.
Why would one remove this? I learned what a charcoal cannister was 30 seconds ago 😅
  • Haha 3
I had to get under there for the new brake line that comes with Camel's high fender kit, killed two birds with one stone.  Once you're familiar with the 867 different types & sizes of fasteners that Yamaha uses on the bike, pulling the fairings & tank is only a 10 min job.  The tank is only held on by the two bolts on the bracket under the front of the seat.
Absolutely, my OCD would keep me up at night knowing that there was 4" of unnecessary hose on the bike.
This is an excellent point, I had just assumed that the little canister was a one way valve for airflow & not a roll over valve.  I'm going to keep it & update the original post.
Simplify & add lightness - Colin Chapman
F*ck the C.A.R.B. - LateApex
  • Dislike 1
“Vacuum caps” are what you’re looking for.
They’re available at any auto parts store and most hardware stores.
Aside from weight, does removing this have any impact on performance?
Those work, but rubber ones always seem to degrade over time, I prefer silicon.  I haven't had any luck locating them locally.
No.
I wrap mine in tinfoil, same for a corn dog and stick em in there. Works like a champ. I do this on my KTM500 EXC too! You can also stick them up front in the skid plate area on the right side. The exhaust heats up good in about 20 min.
Good God, this deserves its own thread!
  • Haha 4
On previous bikes I would just cut a piece of the original hose and plug it with an oversized bolt with a zip tie around it for good measure.
For those of you that have done the canisterectomy, are your bikes still under warranty and do you have any warranty-related concerns with this mod? This seems like a commonsense thing to do, so i thought I'd ask.
Thanks for providing all of the information.
I was on a dual sport ride with my DRZ 400 a few months ago and came upon a couple of bikes stopped along the trail with the riders working on something. I stopped to see if I could help with anything and they asked me if I had a hammer to which I replied yes. I pulled my trusty hatchet from my luggage and walked over to see what the problem was. The stricken bike was a BMW  ADV bike and the carbon canister had come loose, fallen down, and wedged itself between the rear tire and the swingarm; that had to be a sudden stop! The rider was lucky this happened in loose sand and not on the highway at 60 or 70 mph. Anyway he aired down the tire and we cut a stout stick to use as an extension to beat the canister out of there using the blunt side of my hatchet. Once it was out of there they were able to air back up and continue the ride.
So now I refer to my hatchet as a BMW repair tool and I've found a nice place for it under the seat of my T7.
Edited by Tenererian
  • Haha 3
Might be stupid question, but what's the original function of charcoal canister? I don't think european models even have one. It apparently filters out gas fumes? But why? This is some silly US-pollution law? Aren't there much more fumes released when you're actually refilling the tank? I'm baffled 🤯
My European model does have one, but it was an early demo bike. So I'm not sure if that's a general thing.
Also the European models have it. It's also silly EU-pollution law.
The charcoal-filled canister’s job is to absorb fuel vapor that would otherwise vent out to the atmosphere, causing pollution. Vapors trapped by the charcoal are released back into the engine through the purge valve and then burned.
Yep, just checked and there it is.
But still I'm kind of trying to understand the logic behind here. Does the tank it self generate so much vapour vs. filling up the tank. Have to read more about this after I get out from work.
Have you ever left your gas can in the sun?
The issue here is there is no purge valve. The canister just vents straight back into the throttle bodies full-time. I took mine off to get rid of the hard hot starts.
Before I get started on doing this, can someone confirm the diameter of the vacuum caps required and the fuel line? 5mm caps and 1/4" hose ended up fitting snugly @LateApex?
The 5mm caps were perfect & the 1/4 Motion Pro Tygon hose was identical to what was on the bike.
