This topic contains 151 posts. A summary containing the most significant posts is available
  • Community Expert
Thinking of which center stand to buy? The Yamaha oem, SW Motech, Hepco&Becker, etc...
Can You please tell me the pros and cons of the center stand that You have on Your bike.
Anything in the functionality that You may have noticed?
I still have the original bash plate but thinking of buying a better one somewhere in the distant future.
And will not be installing any side pannier racks.
So if You know any combatibility issues that would be nice to know too.
  • Replies 150
  • Views 57.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Hepco Becker:   + Slim to the bike, doesn't stuck out any farther than the sidestand; stays up on aggressive off road; well built;  looks good; fair price; easy up   - The chain ru
  • Having installed both original Yamaha accessories and aftermarket accessories on my Ténéré 700,  my hard learned experience is that in general the Yamaha accessories is made to a different, higher sta
  • @Janka, Here are the pictures that I promised. If You need more or from a different angle, send me a private message.
Posted Images
I have the Yamaha centre stand, it's easy to get the bike up on it but it looks pretty awful and sticks out on the side a fair bit.
SW-Motech. A little less expensive than the Yam.
Easy installation (smart for the spring). Strong. No issue with the Side Stand (with an extension).
Easy to lift the bike.
  • Community Expert
I think that I will go with Hepco & Becker's center  stand, it looks a bit simple and lighter than the SW Motech.
Any experiences off road with these yet? The sw motechs on my Tiger 800 kept bouncing up and down at the slightest bump with audible "klunks". Very annoying, I strapped them down anytime I went off smooth tarmac..
Hebco and Becker weighs "3.8kg". The design seems a bit simpler than the Yamaha OEM.
Anyone know how much the Yamaha OEM center stand weighs?
i went with hepco & beker. happy with it. easy to get on stand.
Good Choice the Yam one came without any instructions and was an epic to fit without them.  Some kind chap posted some on the forum which was a great help.
Cheers Mick
Might be a silly question,
But are there, or will there be any aluminium or titanium center stands available?
The center stand is a very good thing to have, but I'm really trying to keep the weight off the bike as much as possible.
Tazmool
Edited by Tazmool
Tazmool
I do not know anyone made those,
However, since Titanium is strong but brittle at room temperature, so it might not good for shock load.
Also you would require more of aluminium to achieve the same strength as steel, so while it MIGHT be lighter but def will be larger in size.
I think with the right metallurgy either titanium and aluminium would offer good weight savings over steel.
The bike already has an aluminium side stand, (in '15 the Super Tenere went from a steel side stand to an aluminium one to save weight)
Lots of examples of motorcycle frames havin gone to aluminium from steel to save weight, cost being the main reason why a manufacturer would go back to steel.
Just fishing for ways to save weight.
Tazmool
  • Community Expert
Tazmool
Most of the bikes weight goes through a main stand and there are big leverage pivoting forces on getting the bike up on to the main stand; aluminium bends far to easy that is why main stands are made from steel and not aluminium. A Side stand is different as it is only compression leant on. Titanium is a mega super expensive metal and a difficult metal to work. For weight saving no main stand = zero weight gain.
Cheers Mick
Mick, I like that your bike is properly dirty.
Do you find the Yamaha centerstand flops and clanks going over the rough roads?
Does it protrude too obtrusively cornering, etc?
Tazmool
Well, guess someone can engineer one...I would get one if there is a gain 👍🏻😀
I put a Yamaha center stand on mine and it does clunk on landing from jumping, in hindsight I should have brought one of the other brands as the Yamaha item looks a bit agricultural.
Hmmm. I've got a Yamaha one too, but not "off-roaded" it since I fitted it. I guess you could tie-wrap it up when off roading, and then snip the wraps off if you need the centre-stand on the trail i.e. only if you're unlucky enough to get a flat.
Be interesting to know if the other centre-stands are lighter. I think the quality of the Yamaha stand is pretty high and it's essentially bullet proof. You can get on the bike on the centre-stand (should you wish), without even a wobble.
Rich
The one from Hepco Becker has a shorter push rod. Yamaha’s is very sweeping what could be a disadvantage...
Hi No just done over 1000 miles on trails in the Pyrenees and it was fine no clanging about.
Great to know😀
Agree! I fitted a OEM centre stand and it's huge.. The push road is longer then pegs and had problems with it in offroad – hit trees and stumps.
Please, can someone post pictures of Hepco Becker centre stand – left side of the bike, when the bike is not lifted on the stand?
  • Community Expert
Are You in a hurry? I can provide pictures on Friday.
  • Community Expert
Fitted the H&B stand. Total weight with the installion kit is about 4 kg. Easy to mount and seems to work nice.459125274_S_CrossprobashplateandHBcenterstand.thumb.jpg.5c81e7d76f1b1743799d322a88f8b5df.jpg
No, i can wait! No hurry. Thanks!
Received my SW Motech stand today and fitted tonight. Well made, precise fitting, instructions easy to follow.
Spring mount very easy as they have an adjuster. Stand works smoothly and cost quite a bit less than the OEM.
  • Community Expert
