T7 1 Finger Clutch
Camel ADV
1 hour ago, Camel ADV said:
I appreciate you waiting for us to have stock. We had a few reports of the cable clevises lightly dragging on some bikes' OEM crash bar tubes. The same 1FC kit will work on bike #1 but not bike #2. We've got lots of stock on the kits, but we've stopped selling them until we figure out what is happening. We can do another run with a slightly shorter arm, but that's less than ideal. Looking at making changes to the clevis itself. We've been busy with other projects, and this one has been sitting because of it.
Cory,
Thanks for the detailed response. I found one for sale in the UK, but I will hold off until you perfect your issue.
I will gladly buy the first one hit off the CNC machine when it is available.
Keep up the great work!
15 hours ago, roygilbo said:
Just did a tally... 19 @Camel ADV products and counting  🙂
Thanks for the continued support!
  • 5 months later...
On 7/1/2021 at 11:23 PM, Camel ADV said:
If you can fit a nickel on edge between the perch and lever, you have enough free-play.
which are the 2 finger levers recomended to change the original longer ones, for cluth and break?
Edited by GustavoCR
1 minute ago, GustavoCR said:
which are the 2 finger handles recomended to change the original longer ones?
We just use the OEM lever but shorten it a bit.
