X Plane
18 hours ago, cabby said:
Jeezo, you're a bit sensitive aren't you petal 🤣🤣
You don't like my sense of humour? My second degree sometimes is difficult to understand.
Freedom is not a good word for off-road in Switzerland - completely forbiden here.
I finaly choose and install my skidplate.
SW-Motech. Because it has 3 mounting points. One will enforce the frame near the footpegs.
I like the high on the front.
  • Like 7
  • Thanks 2
That is a nice plate with a high front.
Can you tell me:
a)  Do you need to remove the front bracket as well to get access to the oil filter?
b)  Does the plate protect the rear linkage or is the linkage still lower than this plate and likely most plates?
Edited by ADVUSA
typo
Can you tell me:
a) no need to remove the front bracket - to be tested. If yes, not a big deal
b) no
Edited by erey
Nice product but these crash bars skid plates ect spoil the good look lines of the T7 but I guess it s necessary if your doing a lot of your riding in the dirt 👍
unfortunatly yes
On 11/2/2019 at 4:35 PM, erey said:
First test with soft bags. 30 liters each (Enduristan). Not so bad with the exhaust heigh.
I will have the SW-Motech rack. So another way to attach my bags
https://sw-motech.com/en/products/luggage/luggage+racks/ADVENTURE-RACK/4052572179185.htm
How stable is the bike on that lift? I was looking at ebay the other day thinking to get one... Its this or get one that lifts just the rear wheel.
Aleks
Aleks
With the new SW-Motech skidplate it's stable. No issue or problem.
Aleks
With OEM skid plate it would be risky. Yesterday, I made small modification of my old lift and I welded different supporting bolts for it. It's not nice, not painted yet, but it's strong and stable.
Thank you for sharing this..so the new points are on the actual frame not touching the skid plate?
Yes.
I think, the OEM skid plate is too flexible.
Fitted R&G case protectors. Super light but very tough looking. Pleased with them.
Hi, 1st post so go easy on me, this model looks like a good design, the mounting bolts are all flush as far as I can see so aren’t going to get hung up on stuff. It also looks like all the brackets can be mounted on the skid plate so for servicing and cleaning doesn’t leave anything on the bike, am I right?
16 hours ago, erey said:
Just riding. Mud is coming.
Nice decal set.. Could you share where we could buy this...
I've noticed you have oxford heated grips... Are they adventure ones and did you cut the right hand side down?
Yes servicing will be easy. Just few bolts (and they are protected by the design - one of the reason I choose this one).
Kit fun deco in France
https://www.facebook.com/kitfundeco/?epa=SEARCH_BOX
Adventure model for the heated grips. I cut just a little on the right - 1mm because I replace the tube by an R6 compliant
How much did You pay for graphic kit? Can't find any information on their FB..
4 hours ago, erey said:
For your own kit - 230€ and if you use an existing kit 130-150€
Thanks!
Hi Rich, are those bolt on , over the o/e cases or to replace the originals?
cheers,  Bob.
cheers,  Bob.
They're clever as they bolt over the original casings, but you don't have to undo all the bolts. Only 4 each side, so no problem with gaskets, leaks etc. There are metal inserts in the 4 holes on each side, so you don't crack the plastic when you mount them. It also does away with the annoying "sticky-out" protector for the clutch arm which I can feel on my shins in motocross boots or other boots when I ride.
I sprayed the casing and bolts with WD40 before mounting to stop any corrosion underneath (But I'm sure it wouldn't anyway).
Super light and they look super tough. Someone posted on here a crash after fitting them and they saved the casing.
A bit pricey for a bit of molded tough plastic, but great quality.
Rich
Rich
Thanks for that 🙂
