Noel McCutcheon
With Snow forecast tonight; I pushed the Tenere in doors. Lol.
6 hours ago, Bror said:
About 4-5 kilos lighter.
Did you make that rack or buy it?  I would love a small simple rack like that.
Its homemade by scrap metall from work.
On 12/30/2020 at 7:48 PM, BADDANDY said:
Completed 2 free mods today,
I cut the long end of the stock sidestand spring at the middle of the loop and rebent it.  Now the stand retracts with a bang (not as bad as it sounds) and It almost totally eliminates any retracted movement.
Then I completed an Easy Clutch pull mod.
I cut stock lever arm in half, then welded in a 1/2" extension.  Next was to bend in the cable guide to align.
 Finally got to test the mod. Oh my, did this ease the clutch stiffness, especially with thick winter gloves on. Action feels exactly like my TE and FE's hydraulic clutches!
2021 Yamaha Tenere 700
2019 Husqvarna TE 250i
2018 Husqy/Oberon/JD FE 450
Do you have a pattern you can share or did  you free ball it?  To me it’s about the best rack design that I have seen for the T7
Highway pegs mounted. Getting close to cali or bust trip from AZ.
Link
Motorcycle Foot Pegs Foot Rest Highway Footpegs For Road King Street Glide Honda Kawasaki Suzuki Yamaha 25mm 32mm 34mm (Black) https://www.amazon.com/dp/B07Q6BRJZM/ref=cm_sw_r_cp_api_glc_fabc_Zr-9Fb9RY03JS?_encoding=UTF8&psc=1
FAAA5FE6-9647-4E11-B715-A4204B90CA9C.thumb.jpeg.9c6e25089c481f8e0465f87e52d1e8f7.jpegE45218ED-17D1-4FEA-BFC4-CC1D798B11A9.thumb.jpeg.ef9b639ccb067f0f53a81ae3f0baadab.jpegE45218ED-17D1-4FEA-BFC4-CC1D798B11A9.thumb.jpeg.ef9b639ccb067f0f53a81ae3f0baadab.jpeg
Link
Now that's something I can get behind. Thanks for the link! About to buy one myself.
11 hours ago, BLZ2DWL said:
What sort of rack is the aluminum one?
It is made of 2 pieces of 6 mm aluminum bent at a 71 degree angle and 4 iron pipes for the bolts .... yes i did free ball it 🙂
Stripped off the plastics ready for a good coat of look-over and a deep clean. She's a bit mucky underneath!
  • Confused 1
she is damn filthy!
On 1/8/2021 at 4:00 AM, JimmyTheHuman said:
That is brilliant. I wish i had seen this before i bought bark busters!
Hey Jimmy, I did not want to post my temporary OEM seat fix on the SC thread.
If you want to soften the OEM seat . . . Cut the seat pan to allow the firm foam to sink into the seat pan a bit.
It works better than expected.  I still want a 1pc SC Rally low seat . . . if it is not narrower than the stock seat.
you can start with a 1.5” - 2” cut.  It relieves pressure on the tail bone.
2021 White T7, 2019 MT-7, 2021 CRF300 Rally, ‘14 V-Strom 1000 Adventure
On 1/8/2021 at 5:46 PM, CReamflourish said:
I thought the forum rules forbid to post naked pictures 🤣
On 1/6/2021 at 4:59 PM, Porsche911 said:
Happy new year from Barcelona!
So I keep the original hand guards.
This looks good. I like the idea of being able to keep original parts if possible.
How did the installation go?
How does the quality seem?
Fitted underbar mirrors.
not gonna link the ones i used as it required some finagling. But it works and i like em.
I am onto this, brilliant idea. Mine only needs to be a little bit better. I was going to add a gel pad, but i have reservations about actual comfort improvement, heat and durability.
A soft foam pad under the the stock firm foam works too.  I did this on my MT-07 to raise the seat for more leg room.
it maintains the OEM seat shape.  I used a soft exercise foam pad (wife’s yoga pad) . . .
You could cut a section of the OEM foam out from the bottom side to place a soft gel pad.
You can remove the two rubber bumpers to drop the seat a bit to offset a pad under the seat foam
Edited by Tom McDonough
During these days of incessant rain, I took the opportunity to do some jobs on the bike.
The following is performed:
-Powerbronze adjustable windshield
-powerbronze yellow headlight guard
-heated grips oxford adventure
-phone holder with wireless charging
-and finally the little trick taken from the forum
Very easy!
No need to disassemble the originals to put them, you have to open the angle a little to make the curve bigger and that fits perfectly inside the handguard. The quality is apparently good to protect the originals in a normal fall and that they do not break, I suppose that the alloy in one type Barkbusters will be better in terms of resistance to a great impact.
Replace the screws for better ones,  are really bad.
I mount them thanks to this video.
Edited by Porsche911
We are all finaglers in here brother!  Do they work ok?
Yes.
Attached them to the bar weights on the end. Here they are
FENRIR CNC Aluminum Alloy Motorcycle Bar End Mirror Side Handlebar For Honda Rebel Grom NC750S CB Kawasaki Z Ninja Yamaha R1 R6 Suzuki SV650 GSXS1000 Ducati Monster KTM DUKE Triumph Aprilia Husqvarna https://www.amazon.com/dp/B07XRV4RZP/ref=cm_sw_r_cp_api_glc_fabc_pkn.FbJWMAS9B?_encoding=UTF8&psc=1
