Noel McCutcheon
1 hour ago, Rlynn10304 said:
Bare minimum crash protection installed.
can someone confirm these wont imageproxy.php?img=&key=6a3749c85cdc35aemelt
I'll be honest; There's not a lot of things I've put on the OEM exhaust that haven't... melted.
On 1/9/2021 at 11:36 PM, Rlynn10304 said:
Fitted underbar mirrors.
not gonna link the ones i used as it required some finagling. But it works and i like em.
where did you get that tank graphic ( the upper actual gas tank ) ?? I like the look and simple
Hand made. Black Reflective tape from amazon
Qbc Craft Motorcycle Black Reflective Tape Kit 12 Sheets 3.5" x 12" of 3M Scotchlite (Reflects White) Enhanced Road Safety Adhesive Vinyl for Side Bag Bicycles Helmets DIY Decals Tets https://www.amazon.com/dp/B072BC8F4N/ref=cm_sw_r_cp_api_glc_fabc_imO.FbGPQPF93?_encoding=UTF8&psc=1
Edited by Rlynn10304
Installed these today. Makes chain maintenance and winter storage a lot easier. The spools will be unbolted when I’m riding so they don’t snap off when I tip over.
Xitomer Aftermarket Motorcycle Swing Arm Spools, Fit for Yamaha Tenere 700 XTZ690 2019-2020, Motorcycle Stand Bobbins Sliders, CNC Aluminum Alloy (Black)
Giving myself a couple options for caring extra fuel, rear plate or side mount. Either only takes about 5 minutes to setup
On 12/31/2020 at 3:40 PM, CGras said:
Stripped it down even further and treated the inside of the frame with wax. Some portions of the tank and outside of the bike got a coating with  ACF50.
Then I installed a set of engine crash bars.
And some Touratech goodies for the water pump and brake pedal.
And a happy new year everybody.
In hindsight are you happy with and would you recommend the Touratech water pump cover ?? or go with something different ??
On 1/8/2021 at 4:46 PM, CReamflourish said:
Stripped off the plastics ready for a good coat of look-over and a deep clean. She's a bit mucky underneath!
Which crash bars are these?
They look like Touratech upper and lower bars
Uppers definitely are!
Yes, they are Touratech upper and lower.
They've passed the drop test a few times now too!
Cheers, Mike
The other day I went out and put lock tire on the tail tidy fasteners since I thing I forgot to do that when I installed it.
Today I just went out and admired it 😀
Mike
Fitted a set of cheap plastic mirrors. Don’t really like the steel OEM ones being attached to the brake & clutch mounts. Could be an expensive and frustrating end to a trip if you have a wee off.
These ones should hopefully break first and they can be easily folded in if venturing off road.
I received some screen protectors from Speedo Angels at Paulton House, Old Mills, Bristol, UK.
There is 2 of them in the package and will be good considering the amount of dust the screen will be subject to on the Alberta back roads.  I'll review them as soon as I get one of those T7 bikes, and when it quits snowing.
Here's the link
Edited by Landshark
On 1/13/2021 at 6:46 PM, OU812 said:
Installed one of my christmas gifts, my pre and main Uniflow.
I'm waiting on mine but my concern is the bikes fuel mapping . I've read here that there was a stumble at low RPM's on the Europe models and the UNI filters helped BUT the US models have changed mapping and don't experience that and I can vouch for that as mine runes awesome everywhere in the RMP range. So adding the oiled foam main air filter and a pre filter might richen the fuel mixture ?????? Definitely like the idea of the pre filter maybe un-oiled as its added protection and don't want to restrict air flow..
Are many of the US owners using UNI foam filters and what's your experience ????
I have installed a Uni  prefilter, un-oiled.  No noticeable change in performance. May oil it before going in dusty conditions.
I have the same!
Today I installed the Camel Adv "One Finger Clutch". Bought from Rally-Motor (a dutch site).
Hi from Italy
Hi from Italy
Does look good , well done Cory, how does it feel?
I put on the third hole (softest clutch).
(for me the first two have no much gain)
Feeling is very good. Now I drive the clutch really with one finger.
I spent a little to find the exact disengage point (two or three attempts), but now is ok.
Light clutch!
Edited by 365moto.eu
Wish the 1 finger lever worked with the oem crash bars but apparently it doesn’t 😢😢
